Author Topic: Hi From PR!  (Read 835 times)
rolla_pr
« on: August 12, 2006, 08:27:35 AM »
Ok people I have this question...do 4age pistons will fit my 4afe...cause it is the same block and the have the same bore....(81)
Because I`ll try to buy a forged piston set for it and they are leaveng me a gooooood price so yo are the ones that kan help me out...
anticipated thanks guys
this is my car:
http://myspace-438.vo.llnwd.net/00996/83/49/996059438_l.jpg
puertoricanrolla
« Reply #1 on: August 13, 2006, 09:36:07 AM »
hola rolla_pr de que parte de puerto rico tu esta? yo estaba en humacao.
i dont know know if they fit, since one head is a twin cam head and the other i just found out recently that it has a dual cam setup (one cam drives the other)so i dont know if the valve cut outs on the pistons are the same. that will probably be the only thing holding you back. you'll have to look it up in google or something. or talk to a toyota mechanic.
rolla_pr
« Reply #2 on: August 13, 2006, 06:37:39 PM »
na` pues yo soy de aka del area metro (carolina), But i have family in naguabo and I know some people of humakao...
I didn`t know that the valve cut was gonna a be a major problem cause the block is the same...is just that it is a little bit older... but i am researching Also, i founded a forged piston and rods kit (for the 4afe)at importperformanceparts.net
and the price isnt that bad...so I am thinkin on buying it...but iam researching that too...Anyone here have dealed with them?... What do you think?
pd. Na loko kuando puedas i kieras me anades al messenger cool_man_131@hotmail.com suave pai te cuidas
« Last Edit: August 14, 2006, 10:18:04 AM by corollamadness » Logged
puertoricanrolla
« Reply #3 on: August 13, 2006, 08:52:30 PM »
i've never dealt with them nor do i know of anyone who has.
tengo un tio que trabaja de mecanico para toyota en naguabo, pero no se se el esta trabajando todavia
« Reply #4 on: August 14, 2006, 08:04:08 AM »
Quote from: rolla_pr
You are correct on the bore sizes, but you have to look at the wrist pin.  They might be different.  Also, not all 4age wrist pins are the same.  Some years they were 20mm others 18mm i think.
As far as blocks... your wrong. the 4afe and 4age are very different.  they have different strokes.  If the blocks were the same them the 4age would fit perfectly on the 4afe block.  They don't... so there you have it.
Pistons to look for if you decide to use them and IF your wristpins fit would be the gen2 4agze pistons.  They are ceramic coated.  Be advised that toyota has 2 compression ratings for the 4agze pistons: 8.0:1 and 8.9:1.  I recomment the 8.9:1.
XBOX LIVE!!!
Global Moderator
« Reply #5 on: August 14, 2006, 10:19:14 AM »
OT: hey man i use to live in Naguabo, family still there Bo. Mariana
rolla_pr
ok
« Reply #6 on: August 14, 2006, 01:15:35 PM »
thanks don fuskkinrolla for the advice...and some people have telled to me that the 4agze piston actually rised the compression on the 4afe..but I dont have a clearly reason...so I think that I am gonna deal with ipp.com (I will tell you...) or going custom and wait a complete month... so good luck to me Sad
Puertoricanrolla:
tengo un tio que trabaja de mecanico para toyota en naguabo, pero no se se el esta trabajando todavia.
-Eh ke kurioso por ke mi tio en naguabo tambien es mekaniko...jejeje
Corollamaddness:
hey man i use to live in Naguabo, family still there Bo. Mariana.
-Jeje Saludos...Mi tio vive en Rio Blanco kreo ke esta bien cerquita uno del otro...
puertoricanrolla
« Reply #7 on: August 14, 2006, 11:51:59 PM »
que comico, yo me pasaba en rio blanco en casa de uno de mi mejores amigo. tu tio trabaja para toyota? y tambien conosco pal de gente en bo. mariana.
« Reply #8 on: August 15, 2006, 08:01:46 AM »
no problem rolla_pr.
One other thing... you might want to look into 3sgte valves.  Especially for the exhaust side.  They fit.
rolla_pr
hi
« Reply #9 on: August 15, 2006, 05:21:28 PM »
puertoricanrolla-
pues lo ke pasa es ke mi tio lo ke hace es mekanika pero no esta en un taller...de hecho entre el y yo es ke le hacemos las kosas al karro...por eso me pompie a estudiar mekanika...
don fusskinrolla-
Ok thanks again buddy for the advice...and one other question...do the intake valves fit too?
« Reply #10 on: August 16, 2006, 08:03:21 AM »
depends.... on how big your wallet is:-)
rolla_pr
« Reply #11 on: August 16, 2006, 12:47:05 PM »
I got the concept....the dont fit...
pd. If I drive my mind thinking on the size of my wallet...the kar will never move!
ranterc
« Reply #12 on: October 09, 2006, 07:14:37 PM »
while the pistons alone may not work , i think the complete 4age bottom should work... i mean as an alternative to forged rods and pistons.. and then having to rebuild... i'm sure it should work..
its a direct bolt on with no modification with the 4ac , and the 4age head is often used with the 7afe bottom ...
i know with the 4ac you get to keep all your accessories , but i wonder if everything lines up when using it with 4afe?
anyone ever try this? or hear of this being done
[img=200x132]http://www.geocities.com/ran9596/side.jpg[/img][img+200x132]http://www.geocities.com/ran9596/grillesig.jpg[/img][img=200x132]http://www.geocities.com/ran9596/newguage.jpg[/img]
