its an 87 corolla , 4ac 5 speed
i'm not sure if i'm keeping it too llong or what but in the mean time i'm tryiing to do some cheap/free mods that will pep up the engine a little
would like to remove power steering , but before i do that will just remove belt and see if i can live without p/s , then i'll remove entire system
soo..
as you can see the Crank , alt and what i assume is the water pump are under one belt , and the crank , A/c and another pulley that seems to do nothing are on another belt ..
then on the water pulley behing the belt that goes to crank
it is in my opinion that i can remove the p/s belt and it will not affect the water pump, because after all it IS directly run by another belt to crank which is what turns everything ..
Also seems like i would have to remove alternator belt first to remove p/s belt by the way everything is hooked up
is this all correct ?
aslo if i decide to keep it ,once i remove everhthing i know i can just loop the fluid lines in the steering rack to keep everything lubed up , but in the mean time , without the belt and the complete system still in i should be fine right ? i mena no damage should come as long as there is fluid in there?
