Author Topic: A gift to the community: free turbo mapping tool?  (Read 1409 times)
« on: April 03, 2006, 01:16:55 PM »
First of all, not to sound full of my self, but you?re welcome, this is here to help the community to grow and make informed turbo decisions? Second, I barrowed the temp calculator from WilLyons because it was more simplistic and elegant than my original one (If you have a problem with that I will replace it with my original, just say the word)?
I?m posting this because a lot of people who know me keep asking how I map turbo efficiencies so quickly and how I pick turbos? Well here it is? It?s not all that special, it?s just a spread sheet for turbo math, you input your information in the red values at the upper left and the aria at the right kicks all the appropriate mapping numbers back at you so all you haft to do is print the map and start drawing. You can also fined comp outlet and intercooler outlet temps on the sheet and it makes a grate tool to play with setup changes in IC eff and so forth to see how your turbo is affected. You can even correct for altitude if you know you amb press in PSI? The info that is in it is a 1JZ setup I was looking at, so if you?re a 7M guy, remember to change your displacement?
Here you go and enjoy?
« Reply #1 on: April 03, 2006, 01:20:23 PM »
I took the turbo mapping tool a step farther? Put your data in on the ?In? page and get all the info you need on the ?Ans? page, including average mapping for the turbo, injector size and boost press? I?m still working on a version that you put boost in and get out supportable HP? Remember, change only the red numbers or you stand to mess up the form?
Dexterous
« Reply #2 on: August 13, 2006, 01:20:56 AM »
Very interesting; may have some questions to use it right.
Dexterous
« Reply #3 on: August 13, 2006, 05:02:06 AM »
If you have Q's, ask away.
