Author Topic: 1989 Toyota Corolla SR5 - JDM Trueno front end, TONS of new parts!!!  (Read 324 times)
aaron7
« on: March 02, 2006, 07:16:48 AM »
Asking $2000!!!, located in MA. Drive it cross country!!
$5509.90 put into this car, not including things I did myself, receipts I lost, or the cost of the car itself!!
I figure I should try and sell this so I can focus on my other car. I have owned this since May 05, and I have done tons of work on it. There is very little left to do! Here is what is new and I have done:
New (as of 5/18/06) Yokohoma Advan A460 185/60/14 tires - $280.36 + $21.35 mounting
4 wheel allignment (as of 8/21/06) - $55
JDM side skirts, all 4 pieces (not installed) - $115.76
JDM Trueno taillights - $204
Replaced both rear sway bar links - $119.94 parts and installation
Replaced ALL brakes and parts (rotors, drums, pads, shoes, springs, calipers, all OEM or Bendix) - $950 parts and installation
Replaced radiator (lifetime warranty) - $108
Replaced all hoses (upper and lower radiator hoses + one behind motor) - $35.44 + $37.48 labor
Replaced water pump - $46.69 + $131.16 labor
Replaced engine belt - $18.47
Relaced clutch - $186 + $533 installtion labor
Replaced motor mount - $25
Replaced both axles - $240
Replaced exhaust pipe from manifold back - $242.20
Replaced battery - $45
Replaced starter - $93
Replaced timing belt + tensioners - $96.90 kit + $131.16 labor
Replaced clutch safety switch - $89.74 + $37.50 labor + $59.96 diagnostics
Machined flywheel - $35
JDM Corolla GTS spoiler - $25
JDM GTS strut tower brace - $36 + $3 hardware
JDM TRD Quick Shifter w/TRD knob - $155.09
Corolla GTS gauge cluster - $62
Corolla GTS secondary gauges (not hooked up, but installed) - $22
Dash clock (car didn't have one) - $12
Nippon Denso Platinum plugs - $22.36
Toyota exhaust hanger - $45.76 + 27.68 labor
Ractive muffler (not loud, very tuned) - $59.99 + $62.50 installation
Pilot oval exhaust tip - $9.99
Brass PCV valve - $2.56
PCV grommet $1.98
4" chrome air cleaner - $12.88
Trueno hood and front bumper- $450 + installation (bumper sells for $400 on ebay alone!)
14" Proline rims - $128
KYB GR2 struts, all four - $190 + $40 install (special deal haha)
Fuse box contacts had corroded, paid $213 to have cleaned up
Car has a sunroof and power mirrors. No AC, no power anything else. Very light!
Pop-up lights work like new. All Trueno front lights are wired up.
Interior is mint. No stains or wear except for 3" or so on driver's seat bolster. Needs a cleaning, not bad though.
Exterior is in black priner. Almost ready for paint. Only rot showing is rocker panels under the doors in the rear, and some in the lower quarters (hidden by bumper).
Car does not smoke or make any noises. No leaks. Mechanically it is sound. Carb could use a little tweaking though, doesn't like to go when cold. Might be the accellerator pump.
Needs a windshield due to a crack on the passenger side.
The car is daily driven with no issues.
Tons of pics available, please ask.
Perfect light (low options) car for a 20v swap!
http://www.cardomain.com/ride/2290135/1
Some pix below show older parts... the lack of the JDM taillights, old tires, etc.
« Last Edit: September 28, 2006, 09:32:30 AM by aaron7 » Logged
1989 MR2 - 3sgte swap in the works
1993 Grand Cherokee - 5.2 V8, intake, exhaust, 2" lift, RE Monotubes, Mopar ECU, and 31"s
aaron7
« Reply #1 on: September 28, 2006, 09:31:31 AM »
