Author Topic: Map Sensor for 3s-gte  (Read 563 times)
mkiii_kelly
Semi-Newbie
« on: January 08, 2006, 09:02:39 AM »
How many BAR or psi is the map sensor?
« Reply #1 on: January 08, 2006, 10:16:31 AM »
According to this site it flattens out around 18PSI:
http://gtfour.supras.org.nz/mapsensor.htm
And this guys talks about adding an LED light to warn you:
http://www.speedtoys.com/~marcel/t-tech/led-fcd-tech.html
TheHorniak
Semi-Poster
« Reply #2 on: January 08, 2006, 11:33:28 AM »
they call it a two bar. no sure why cause 2 bars is like 29psi
im selling one for $75 obo.
Ben
Semi-Newbie
« Reply #3 on: January 25, 2006, 07:19:53 PM »
Quote from: TheHorniak
2 bar is about 29 psi.  It can only measure to about 14.7 psi of positive boost pressure.  The reason why it is 2 BAR is because it measures from -14.7 psi to + 14.7.  Before boost is created there is actually vaccum created therefore resulting in negative pressure.  So if you want a MAP sensor that will measure past 15 psi wou'll need to go to a 3 BAR.
BBoYRuGGeD
« Reply #4 on: February 04, 2006, 04:21:58 AM »
the 3sgte map sensor measures up to 17.4psi (4.2v seen by the ecu if im not mistaken)
bboy
« Last Edit: February 17, 2006, 12:44:28 AM by BBoYRuGGeD » Logged
