Author Topic: 4EFTE Tercel Swap Info  (Read 2501 times)
« on: October 29, 2005, 05:22:58 AM »
Tercel 4EFTE swap checklist:
Stock mounts/axles
Custom exhaust hookup
Custom wiring
Throttle cable from a Paseo
Fuel pump for '97+
Modify hood for TMIC or
FMIC - $225
FMIC Piping (4 45* bends, 5 90* bends, couplings and t-bolt clamps)- $300
Fonz87
« Reply #1 on: January 30, 2006, 11:18:05 AM »
How Help me out with this.. i dont know how to put it in right words so try to get into my mind and help me out what im tryin to say...
I have to do a Manual Converison .. what m i going to be needing....      Clutch Pedal with Parts with it  and then also that   Shifter thing it to change the Automatice thing to manual..   WHat isthat Called !! help me  Smiley
« Reply #2 on: January 30, 2006, 06:36:29 PM »
Here you go Smiley
http://www.northeasterntuners.com/forums/showthread.php?t=2575
Fonz87
« Reply #3 on: February 27, 2006, 06:59:07 PM »
hey tweek it says Fuel pump 97+   whats does that mean also FMIC on the bottom of that Huh  I dont  understand this.. When i do the engine swap.. well Im ganna be getting the engine with 5 Speed tranny and ECU and wiring harness with it .. hopelly complete wiring stuff ... ok lets say i got all of that..
 no welding done to it to install the engine or yes Huh anything custom done to the engine bay to fit the engine or no ??  i know you got custom wiring done for the engine.. Hay also Do you have a Starlet Engine Wiring Diagram.. if you do .. i was wondering if you can scan it and email it to me  to  Fonzarellijr1@yahoo.com   thz . ..
Hey also.. You said to use the manual assembly out of a Tercel.. can i use the one out of a 95 + tercel... since i have a 94 .. ??   Sry dude.. i have many question in my head..  if im annoyiin .. you .. im sorry.. i gotta know all this before summer time comes.
« Reply #4 on: February 27, 2006, 10:15:29 PM »
In the '97 and newer the fuel pump is weaker and won't keep up with the 4EFTE, so you need an upgraded one. FMIC mean front-mount intercooler, you could do without this if you want to go with a hood scoop or even leave the stock intercooler under the hood with no vent (bad idea).
No welding, all stock mounts. Custom wiring needed, I can do it for you ($350). I do have those diagrams and I'll try to send them to you.
Yes, the '95 stuff should be fine.
Fonz87
« Reply #5 on: February 27, 2006, 11:10:46 PM »
what kinda of fuel pump i should go with ?? the one i have right now.. works or no Huh
« Reply #6 on: February 28, 2006, 12:20:47 AM »
What year is yours? If you have a '97 or later, just get a Walbro 255, I can get you one for like $100 shipped.
Fonz87
« Reply #7 on: February 28, 2006, 08:39:14 AM »
mine is a 1994 Tercel Sedan DX
« Reply #8 on: March 01, 2006, 01:55:42 AM »
Then you're fine.
Fonz87
« Reply #9 on: March 01, 2006, 10:19:07 AM »
how much is a front intercooler for a Tercel or any kind .. thats a good one .. but cheap. I dont wanna like cut up my hood and put a Hood scoop and then when i get a Intercooler.. then there is not use for the Hood Scoop ... you know what imean Huh
« Reply #10 on: March 01, 2006, 11:59:53 PM »
Yeah sure. About $200 for the intercooler, you want to add another $400 for the mandrel bends, t-bolt clamps, silcone connectors, and shipping. $600 total.
Fonz87
« Reply #11 on: March 02, 2006, 04:31:07 PM »
but you know i heard from a friend of mine .. that i can use like plastice piping or those pipes they use for home buildings or whatever.. that are strong... He said i can use those for intercooler pipes expect that pipe thats leads to the Intake Manifold. i think. for the Waste Gate
« Reply #12 on: March 02, 2006, 11:10:49 PM »
You'll never see that on any car I build. Smiley
Fonz87
« Reply #13 on: March 03, 2006, 10:47:10 AM »
so Doc, i was wondering if you happen to find that Wiring Diagram for a Starlet .. 92-95..   Also i was wondering if you have a Tercel Wiring Diagram to ... 1994.   so i can learn both of them ...
Stealthseo
Semi-Poster
« Reply #14 on: July 20, 2006, 02:33:52 PM »
hey, I am doing the same thing but in a paseo is the wiring different then a tercel and where can i find diagrams for wiring?
« Reply #15 on: August 01, 2006, 09:15:54 PM »
The wiring is a little different in a Paseo.
The diagrams are available online if you look around, I've got them somewhere as well if you need them, you can email me.
Or just send me the harnesses and be done with it Cheesy
Stealthseo
Semi-Poster
« Reply #16 on: August 02, 2006, 10:07:01 AM »
so you just need the harness? or is there anything else i need to send? and how much?
« Reply #17 on: August 03, 2006, 09:40:18 PM »
I need both harnesses, the 4EFTE harness and the engine harness of the car it's going into. I'm running a special right now for that conversion, $300 plus $30 for shipping.
Stealthseo
Semi-Poster
« Reply #18 on: August 04, 2006, 02:26:37 PM »
i dont have the 4efte harness they just cut off everything i have about an inch on the ECU and the engine
« Reply #19 on: August 06, 2006, 04:23:26 PM »
Oh that's okay, I can probably still work with it if you send me everything you've got left from the 4E and your 'Seo harness.
