Will sell it for $2000
firm.
If you are interested, hit me up.
Car is in better shape than when I got it.
Additional info on the car here:
http://board.tercelonline.com/viewthread.php?tid=20978Erebuni kit:
Quick story:
I picked up the car from Anthony in Tampa, Fl. I was driving it back and about 210 miles away from Tampa (just turned west onto I-10) the tire tread seperates and pulls the harness from the underhood fusebox to the indash fusebox. Me and my brother-in-law rewired it. I have yet to be able to get the indash clock to work or the dome lights. The cop that tried to push my car off the road was a certified dumbass and pushed the spoiler right off. So now that needs to be put back on. Minor stuff. The radio is stock, needs a new one with new wiring though. A/C also does not work, the compressor and lines are in the trunk and it needs to be reattached, pull a vacuum and recharged with R134a. The power steering pump also needs to be put back on. It's a 5speed. It had an engine swap not too long ago. It's the JDM 5EFHE. The 5EFHE is 110hp. Stock clutch, but has a short-shifter. The 5EFHE came out of the Toyoa Cynos and Toyota Sera. The car has 142,XXX on the body, about 24,XXX on the engine. There's a leak at the intake manifold gasket, it needs a new one (I have a new one, just have yet to put it on). There's a drip leak most probably coming from the front crank seal or oil pump gasket area. Other than that, the car is great and unique. The wheels pictured in the first 4 pictures WILL NOT BE INCLUDED BECAUSE I DO NOT HAVE THEM. The car is equiped with 14" steelies with Yokohomas on them right now. Less than 2k miles. The title is in my name. The registration has not been done into my name. The car will not pass inspection in Texas. The tint on it is 2.5%, there is no catalyic converter, and the C.E.L. is on because of three hanging sensors (which you will find more info on in the provided link above).
The car is currently located on 1960 FM in the Champions area. Houston, Tx.
