Author Topic: 1MZ-FE vs. 5E-FHTE  (Read 522 times)
RedSeo
Sometimes Poster
« on: August 23, 2005, 07:55:03 PM »
Lets see what you people think...
I talked with Dr. Tweak, he could do the 1MZ-FE swap.
I went out to a meet tonight and saw the car I want to beat. A turbo sentra putting out more than 250whp in a 2700lb car. Max boost, over 320whp.
1MZ-FE from the 1997+ Avalon puts down 200hp.
I'm starting to think about this:::
http://www.turbo-kits.com/tercel_turbo_kits.html
Putting that on my 5EFHE...
With that I should be putting down 171.6hp to the crank with the T25. That' according to the web site's 56% HP increase. That's a 61.6HP increase...
I'm going to upgrade to the T28Dual BB turbo.
If I don't get that kit (which according to lots of people ((Dr. Tweak included)) those kits are problematic). I'll go to http://www.turbochargers.com which is a local speed shop here in Houston... about 20 minutes from the apartment. Have them make a custom kit.
What do you guys seriously think? 1MZ-FE or 5E-FHTE?
puertoricanrolla
« Reply #1 on: August 23, 2005, 08:07:36 PM »
so your interested in putting in a 6cyl in a tercel??? which would be awesome especially turocharged and if it fits. if the the tercel than what car is this for?
RedSeo
Sometimes Poster
« Reply #2 on: August 23, 2005, 08:50:17 PM »
1992 Toyota Paseo 5EFHE powered
asg14
« Reply #3 on: August 24, 2005, 12:34:12 AM »
:twisted:   If you go with the 1MZ, add on a TRD S/C (has to be 97+ 1MZ Avalon or Camry) and get the 6PSI pulley upgrade,  :twisted:  :twisted:  :twisted:   Be good for another 50+HP  8O  8O  8O
My Camry has a Stock 1MZ with a 4-speed auto, and it has some balls on it.  Smoked the tires a couple times too.  :-o
« Reply #4 on: August 24, 2005, 01:31:33 AM »
Personally, I'd go with the 1MZ.
BBoYRuGGeD
« Reply #5 on: August 24, 2005, 03:10:29 AM »
listen to the doc.!!  1MZ
 :twisted:
bboy
puertoricanrolla
« Reply #6 on: August 24, 2005, 05:36:54 AM »
thats is going to be insane a 6cyl paseo!
i dont know the size difference between the 1mz and the new 3mz (sienna, camry v6) but that motor has some balls as well. when i first got the van i was smoking the tires just by tapping on the pedal.
V6-3300cc- 3MZ-FE
24 valve DOHC with VVT-i
Bore and Stroke: 92.0X83.0mm (1MZ-FE was 87.5X83.0mm
Compression: 10.8-1
230 hp@5600RPM (1MZ-FE 210@5800)
242lb.ft.@3600RPM (1MZ-FE 220@440)
Timing: Interference engine
New VVT-i valve timing and cam profiles
Valve adjustment via shims on top of followers.
32 bit ECU
Rated as ULEV-II
