for about a fourth of the cost I got my suspension..... and i wouldn't trade it for the WORLD!!!
I kinda don't see the purpose of that, unless the car is seeing stricly circuit duty. And in general, if you spend about $800 you should have a very decent suspension set-up: Chamber plates, shocks, springs, bump stops, and sways, endlinks, and member braces.
But again, you gotta match things correctly, cause some parts don't mix well.
If you drove my car through twisties you'd change your mind about full coilovers. You can;t beat full adjustability. Plus, for $50/spring I can get stiffer or softer springs
