Author Topic: tire quest.  (Read 651 times)
100bajan
« on: December 29, 2004, 02:51:18 PM »
Hey gang, I have an 03 corolla S, I presently have 205/50/16 from a celica gt on, and lowered on H&R Race springs, about 2" drop. I want to get wider tires but am afraid they will rub. I was thinking about 225/50/16, bu tif they will rub, I was also thinking of leaving the front and widening the rears only, what do you guys think? If you think I should just widen the rears, what size tires should I get, thanks
Island Man
Storm
« Reply #1 on: December 29, 2004, 06:16:34 PM »
225's might not fit, well fit correctly on those wheels and if they do fit they might actually make your handling a bit worse. You might just want to go with 215s depends on the actual width of those wheels. For 225s to fit right you'd need those wheels to be at least 7.5" wide. I doubt the celica wheels are that wide, especially the 16s.
As for widening just the rears...why? it's front wheel drive and unless you plan on going into corners full speed then jamming on the brakes at the apex of the turn..wide rear tires won't do anything for you.
As for rubbing. Go on the www.newcelica.org and find out the offset on those puppys. Then you can find out how wide you can go with what offset and the width of the wheel
100bajan
« Reply #2 on: December 29, 2004, 07:44:39 PM »
thanks for the quick response
Island Man
« Reply #3 on: December 30, 2004, 06:33:06 AM »
why you wanna get wider tires to begin with?
205 is more than good enough.
wider is just gonna make you slower.  unless that' what's your aiming for :stern:
Martin11581
« Reply #4 on: December 30, 2004, 08:06:30 AM »
the more weight u put in the ride, u slower u go  8O
« Reply #5 on: December 30, 2004, 08:10:51 AM »
i got a spare tire growing on my sides... if you want it you can have it :gap:
Martin11581
« Reply #6 on: December 30, 2004, 08:20:33 AM »
What size tire u have?
« Reply #7 on: December 30, 2004, 08:36:53 AM »
36in waist.
Martin11581
« Reply #8 on: December 30, 2004, 09:07:02 AM »
oh damn, now i get it, i'm all late about lol  :oops:  :oops:  :roll:
Storm
« Reply #9 on: December 30, 2004, 12:58:51 PM »
Quote from: Don Fusskinrolla
Not really true unless you go super wide like 255s. Plus it also depends on the wheel you getting. If you have 18X8 motegis hell yeah they're going to slow you down cause they're 200 pounds each. You you get 18x8 volks, OZs, or SSRs and they definitly won;t slow you down in any way., but there is some truth behind your reasoning. Wider tires usually mean better traction, which from a stop will get you going faster to begin with. Plus you can do twisties a hell of alot better.
Quote from: Martin11581
you used to have chrome rims..what the hell are you preachin about..hahaha...j/k
Martin11581
« Reply #10 on: December 30, 2004, 03:51:04 PM »
Quote from: Storm
Thas why i was always the slow one  :roll:
Storm
« Reply #11 on: December 30, 2004, 05:42:43 PM »
Quote from: Storm
I did always love your bumper though that looked so good...ok back on topic...
tires...goood
hwlcd69
« Reply #12 on: January 05, 2005, 03:04:54 PM »
My gf wants new tires and 70 to 75 is not that much difference on her 4runner that it'll rub is it?  I'm looking to get her 265/75/16 instead of the stock 265/70/16.  I'm looking at the
Firestone Destination LE ~$80
http://www.tirerack.com/tires/BigPic.jsp?tireMake=Firestone&tireModel=Destination+LE&sidewall=Outlined+White+Letters
Bridgestone Dueler H/L Alenza ~$120
http://www.tirerack.com/tires/BigPic.jsp?tireMake=Bridgestone&tireModel=Dueler+H%2FL+Alenza&sidewall=Blackwall
or the Bridgestone Dueler A/T Revo. ~$120
http://www.tirerack.com/tires/BigPic.jsp?tireMake=Bridgestone&tireModel=Dueler+A%2FT+Revo&sidewall=Outlined+White+Letters
 I don't think I need an agressive tire like the A/T Revo but I like the tread pattern. What do you guys think and where can I get them for cheap.  What other tires you recommend?  Thanks
 1998 Corolla VE
91K miles
5 Speed
www.cardomain.com/id/hwlcd69
www.s93713878.onlinehome.us/index.html
2002 Corolla S Red Cluster
185/65/14 Falkens Ziex 512
Brembo Blanks Rotors
2 12\" JBL
4 channel 400 Watt Laguna S
Storm
« Reply #13 on: January 05, 2005, 05:55:26 PM »
Quote from: hwlcd69
the problem with changing the overall diameter is you'll off set the speedometer. for example since you're increasing the overall diameter of the tire the speedo might say 30, but she'll be going like 35(not exact just an estimate) why would you want a bigger sidewall especially if they're already 265/70's
Martin11581
« Reply #14 on: January 06, 2005, 07:46:34 AM »
STORM So when someone changes thier rims and tires to a bigger size like say 18's, that will also offset the speedometer???
hwlcd69
« Reply #15 on: January 06, 2005, 02:00:51 PM »
Quote from: Storm
because 265/75 are cheaper then 265/70
I think that as long as your overall diameter (from one end of the wheel to the other end.) are the same. you're gonna travel the same speed.  but if it it changes in anyway. There's going to be a difference between your actual speed and your spedometer.
 1998 Corolla VE
91K miles
5 Speed
2 12\" JBL
